Automatic transmission not sure what model ???
DennisFY
1989 VN 5Lt V8
Dose anyone know what make or model this Automatic Transmission is ?
I have a CJ6 Jeep and in her is a VN 304. I was told it’s a VN Transmission But the Transmission looks different to the blueprints I’ve been given.
I’m not to sure.
It’s not shifting out on first gear and I’m looking for the shift governor Solenoid.
Or work out how to fix the problem.
Kind regards to all.
Comcal76
Hobart
VP v6
Remove the governor and clean it the valve might be stuck, it's under the round cap at back of transmission.
gtrboyy
vt ss & lc gtr
th700 - from vn/p models
can see kickdown cable that attaches to throttle body...vr onwards are 4l60e controlled by ecu
shane_3800
35
places
vr commo
The governer use centripeadal force to push on a plunger this plunger is the valve. This is what determines the speed of the output shaft so the box knows when to shift. 4l60e has a tone wheel and electric speed sensor instead of a governer.
