Vs hsv manta
- Nov 7, 2012
- 340
- 6
- 18
- Age
- 40
- Location
- Mackay
- Vs hsv manta
This is technical, it's not a matter of making it stiffer
Its resident frequency that causes the problem, and you need to change that witch can be difficult
Think of the Tacoma bridge it is a similar type of issue
Some get it and some don't, some times changing bits of suspension or bushes will change it and some times it won't
I changed to pedders XA coil overs put all nolathane bushes and I strengthened cradle extensively put new rear axels and they all changed the way it did it but it still tramped at times
G force level 3 rear axels have solved this by making one axel thicker then the other witch changes its resident frequency and fixing the problem
It's mostly a manual car with IRS that has this problem and all have different theories on what fixes it as even the same Model car will be fixed in different ways I.E suspension or bushes or harrop diff mount or what not
Sadly its a matter of changing thing till it stops but can be costly and still have the problem
Tyres have a big affect as well
Myn stoped after rebuilding diff and changing to 3.9 gears but I had my diff rebuilt years ago with factory gears when I changed all bushes and suspension and it didn't stop it back then
