back right power window is getting stuck
vxberlina123
tyler
vx berlina
im just wondering how i can fix this. im an apprentice electrician so it probably makes it a bit easier so u probably don't need to go into massive detail although if its needed then yea go ahead.
thanks
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
A bit more detail maybe. Is it random, when going up, when going down, is it in the same place every time?
vxberlina123
tyler
vx berlina
sorry um well i can control it from the front, but i cant control it from the back and when i do control it from the front it goes reallly slow and sometimes gets stuck and i have to physically hold the top of the window and help it up.
and i forgot to add that i cant ocntrol the back left one from the front at all but u can from the back.
i dont know whats wrong and i dont know how to fix it
accentstencil
71
As DanVN said in your other thread, it is probably the same thing that is scratching the window tint, something is rubbing against it. You will need to remove the door trim to see what is going on.
Buggy
VE Berlina Standard MY9.5 :(
I had a similar issue with my front window and found the plastic runner that moved horizontally on the electric window mechanism split. Hope it helps.
