back seat removal
sarj
South Adelaide
VK CALAIS
hey, i got a vk calais (headrests if that makes any differnece) and i wanna get the back of the back seat of to run wire?
how do i get it off?
cheers
NORTI
Crazy VS lady
Radelaide
Wildtrak
remove headrests, then carefuly twist & lift black plastic pieces from the top of the rear seat that holds the headrests in.
Then remove seats as normal. Start with bottom seat, lift from the back of bottom seat push down on front & lift back at the same time, lol its hard to explain but once you do it & get it off you will see why.
Then undo clips for top part at the bottom of top seat at the far side its a little clip over a 'U' shaped hook. Then the seat just lifts out.
HTH
D.
sarj
South Adelaide
VK CALAIS
hey cheers for the help on that, i see wat u mean with the bottom!
i couldnt get the back off but i could lift it up eough to run wires. some of my holders for the head rest posts are broken off so is there another way to undo the top of the seat becuase i need to get the parcel shelf out.
thanks
james
