Bad Brakes
jazzawithvg38
VG Exec
G'day all,
been having troubles with the brakes on my ute,
the problem is that the pedal is really soft and touchy,
only works half the stroke
Has a full hard pedal when engine is not running,
as soon as the engine is fired pedal is not good.
parts replaced so far
brake booster
master cylinder
proportioning valve
new rotors and pad all around
calipers have had new seals installed in front and new calipers in rear.
Any thoughts or suggestion's???????
muttley383
Donating Member
VR 383
Since you have replaced nearly everything. As suggested above, the brakes may need a proper bleeding. Do you have ABS?, if so you may need someone with a tech2 so the ABS actuators can be turned on to allow correct bleeding process.
Are you loosing any brake fluid?, do you have a damaged brake hose that may be swelling under pressure?
jazzawithvg38
VG Exec
Yeah bleed the brakes many times Reverse flush ie pushing fluid in,
and convential way. not losing any fluid and no vechile does not have abs,
Cant say 100% that the lines are all good but i have cheched them very closely and they appear normal. Thanks
