Bad crank angle sensor
Turbovg
Christchurch
Vg v6 ute
Hey fellas just after some knowledge/ advice a while ago I brought a mazda b2000 ute with a buick 3.8 swap thing was awsome but life happens and i had to sell it,
Long story short i brought it back and now seems to be going through crank angle sensors like tictac’s and idea’s on what could be causing it?
Cheers fellas
losh1971
North Tas
VE Series I SS Ute
Are you fitting OEM sensors?
losh1971
North Tas
VE Series I SS Ute
Series I VN or series II. Series one need to have the air gap set, pretty sure this changed with series II.
Turbovg
Christchurch
Vg v6 ute
Update: sent a new crank angle sensor over to be installed being that im away an cant work on it atm and still has no spark
So coils/cpm , cas, still no spark aparntly they had tried another ecu on it aswell but that didnt seem to help anything i am kind of stuck
Its Series 2 also but thinking outside the box here would using a ecu out of an auto on a manual be somthing that could possibly be the issue?
losh1971
North Tas
VE Series I SS Ute
Have you got a code saying failed crank sensor? If yes then it's probably the DFI as it will often throw you the same numbers as CAS, which makes it a bastard at times.
Utel67
Tasmania
Vs s3 ute
Ecm's are the same so that should be fine.
Turbovg
Christchurch
Vg v6 ute
Ill have to have a look being that its swapped and not factory im not sure how I would go with doing a code check wether the plugs there to do the old paperclick trick
Turbovg
Christchurch
Vg v6 ute
Ok so finally got a chance to get my hands on this ute and ive gone through replaced coils/module, balancer & cas, ecu and still no spark hmm im very lost at this point
