acarmody
Donati..Whoa Green
- Apr 29, 2007
- 5,920
- 56
- 48
- Location
- Brisbane
- VX Berlina
Well, I don't claim to know it all, but I've never heard of a broken cam bearing. They are fully supported within the block and sandwiched between the block and cam - how would you "break" one? I've heard of loose cam bearings which have drifted out of position within the block, but not broken ones.
As already said, the problem will be interesting to solve. Keep us informed.
They didn't specifically say broken, just that it doesn't sound right. Very hard to diagnose an internal engine problem without pulling the engine apart.
I bet on the starter motor, probably has worn out, and different temperature makes certain metals sizes increase/decrease, and that could be the reason it only happens sometimes.
I believe that the starer motor IS becoming stuffed. A starter motor not properly disengaging would likely of produced that rattling/gringing sound that the car was making. Unfortunately (or fortunately) the sound has come back since so we can't pinpoint the exact source. I will likely get the guy pulling the engine out to replace it anyway.
Is the noise in time with the revs of the engine? or is it more random? Could be something simple - don't let the mechanics take you to the cleaners
Yeah the noise is there all the way from idle to full revs, gets louder with revs. I have already had all the lifters replaced not long ago, and rockers and springs are fine.
I don't think my mechanic is likely to rip me off as they said they don't do engine rebuilds, so they aren't going to do any of the work. They did recommend me to a guy who apparently is pretty good with this sort of thing (engine rebuilds and swaps). I went and talked to him and he thinks the same thing about the bearings. Also this guy is cheap because he works for himself and doesn' have to pay any staff. He said about $1100 plus parts to remove the motor, strip it down, re-ring the pistons, new crank bearing, fit camshaft, new camshaft bearing and rebuild while checking everything as he goes.
He said that it was possible that the higher ratio rockers might be putting more pressure on the camshaft because the higher ratio means it pushes the springs down more, therefore it places more pressure on the camshaft, or something like that. Any ideas?
