Badge removal and re-installation
trav-p
adelaide
ve berlina sportswagon
hey guys,
want to take the badge off the back off my ve wagon, plasti-dip it, and then put it back on. If there are no locater holes how will i be sure to get it back in the same spot, and what should i stick it back on with? or do i even have to pull it off to dip it?
cheers.
Kunu
chasing the big 300!!!
forums.justcommodores.com.au
97VT SSsuper6(179rwkw),daily barina,2008 VE Clubby
davey g-force
I'm a sceptic...
"...the winner is..."
02 RX7 S8 Spirit R 13B TT & 2013 Audi A3 1.8T DSG7
Just use four small bits of masking tape or painter's tape for locating.
Badge removal is easy - just use fishing line and Prepsol. (Search for a thread called "How to Debadge your Car in 10 Minutes")
As for putting it back on... I don't think double-sided tape is strong enough, or small enough to get behind all the little intricate bits without looking like ****.
Personally I'd just buy a new one from Holden - they're not too expensive and they have the adhesive already on the back. Then paint it and stick it on! :)
trav-p
adelaide
I was just checking ebay, thought they might be cheaper $55....
Kunu
SS-REX
42
THE GC-QLD
03-VY-SS-UTE
You don't have to remove your badges if you want to plasti dip them.
Emmcee1
39
Gold Coast
2010sv6 wagon
On past cars I just used to use a heat gun or dryer to melt the glue behind the badge and just use fishing line in a sawing motion the remove the badge. Use goo remover to clean excess gunk. As for re attaching, I've never done as I removed mine but never put back on. Don't know what ve ones are like pin wise either as I havnt removed mine.
jr_
Donating Member
VE II Sportwagon
If there are no locater holes how will i be sure to get it back in the same spot.
No locating holes in VE wagons (only early VE sedans, '06 and some '07 models)
This stuff has worked a treat on my VE wagon, the badge has been on for about 3 years now: 3m automotive double sided tape | eBay
Yep, easily done, here's some Youtube How To's : https://www.google.com.au/search?ne...sedr...0...1c.1.59.serp..6.5.1316.c9bJKnSNi_Y
