Balance Shaft Bearing how much 4 replacement!!!!!!!!!!!!!!!!!!!!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Joey_21, Jul 21, 2006.
  1. Joey_21
    Joey_21 New Member
    Western Suburbs
    VY SV8 HBD---mmmm LS1
    i recenlty discovered that thiss rattling noise from behind my manifold and Y pipe was the cause of the balance shaft bearing is done does this cause more damage if i leave it i think the rattling is getting worse but once it heats up its u cant hear it until it reaches high revs but its still not as bad as wen its cold anyone have any idea how much it wood cost 2 get it fix i heard its costly and very time consuming $$$$$$$$$$$$$$$$$$$$
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Dunno what the figures would be .....however the workshop manual indicates a complete engine disassembly is required to repair/replace the shaft/bearings. As you can pickup a reasonable VR for $3 to 4000, and a full engine teardown will cost $2000, you'd be better off financially getting another car.....or just drive it till it stops.....
  3. Dragz
    Dragz New Member
    SE.MELBOURNE
    VZ
    .....or just drive it till it stops..... Ouch! its a VR calais daim what a shame.
    The thing i would do is sell the car now while its running than waiting for it to F*ck up and then sell it coz u know it will be worthless. :D
    Dragz.
  4. Joey_21
    Joey_21 New Member
    Western Suburbs
    my olds will prob pay 4 a reco i like my car its got everything i want and i have put a bit of work in2 it and dont wish 2 sell it so il see wat happens
  5. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    You can always try a heavier grade of oil - I'd be running 20/50 grade as a minimum. If the car has 200K plus, then go for 30/70 or whatever they call the oil designed for "older cars" - it won't harm your engine but will quiten rattles.
  6. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    i got myn balenced only a couple of months ago. $700 for balance and $1250 if you want a new one. hope this helps.
  7. Joey_21
    Joey_21 New Member
    Western Suburbs
  8. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    I could be completely off tangent but the balance shaft is not something that you balance - its reciprocating mass cancels out vibrations from the crankshaft/pistons/valves etc which are a problem in a V6. From what I've read, its the bearing/s that fails on the balance shaft and I'd imagine the shaft then oscillates and thumps/clunks or rattles. I could be completely wrong however.
  9. Torquen
    Torquen Boost FTW
    Perth, WA
    450+ HP FORD XR6T
    yeh not a prob now m8.
  10. Joey_21
    Joey_21 New Member
    Western Suburbs
    yeh i think its not possible 2 balance it sumthing 2 do with the actual bearings and old age of the car just worn out and become loose or sumthing which causes the rattling and if no fixed causes more damage etc
  11. Murdoch
    Murdoch Active Member
    VF II SSV Wagoon
    you're right.
    It sits above the camshaft and rotates the opposite away from it.
    I reckon it would be a bastard to fix. Have to take off the timing cover etc.
