balance shaft bearing noise
ryan1980
VN
Hi all,
I have a rattling, which my mechanic says is coming from my balance shaft bearing.
He says he doesnt have time to change it for me (im guessing this is a bad sign)
Is it a big job, what's involved and how much should i expect to pay to have it fixed?
anyone know someone who would do the job north of the river (perth) ?
Ryan
centy
Vp series 2
huge job.
Mate if you can't do it yourself then get a replacement engine.
there are 3 in the engine.
the engine will need to come out for the front or rear one.
It's equal to changing a cam bearing.
ryan1980
VN
****. I just changed the engine :(
This engine had no noise until just now :(
might just put up with it... reckon it could do any damage?
Zuicider
Banned
Stonedville
Set of thongs
the engine doesnt need to come out use a slide hammer . can be done but yer too much trouble, the only real problem is when the bearing dies, jams it up jams the cam and detonation if your unlucky plus the **** from the bearing going through your engine
ryan1980
VN
****, ill ring a couple of places n try get a quote tomorrow to fix it.
tully2007
VR Executive Wagon Manual
Is the rattle there all the time or just on cold start ups? There is only one (1) balance shaft which is in the centre above the cam shaft.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
if it is real stuffed just take the timing cover off and discard the cog off the balance shaft do it doesnt spin problem solved
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
This is what I'd do as well - do a search on this forum as someone else removed the drive gear off the end of the balance shaft - he noticed only a slight vibration so reckoned he was happy with it.
ryan1980
VN
yeah its always there, actually it's more noticeable as the engine warms up.
Is there a write up somewhere on how to remove the cog? or at least the timing cover?
tully2007
I would recommend you get a "Gregory's service & repair manual". It will give you all the info you need. Should be able to get one from an auto-parts. About $70 I think, been a while since I bought one. Worth every cent.
