BANG over speed bump
DOS_SSV
2011 SSV UTE
G'day
My SSV ute normally has a slight scrape over the speed bump outside my work, but the last two times I've gone over it, it has had the same slight scrap, and then a massive BANG! I hopped out today and looked and it appears the whole undercarriage is hitting the speed bump, any ideas what could be causing this all of a sudden? Nothing under my car has fallen or sitting lower. I just want to get it fixed before I do some damage.
Steve
Heron SSV
Central Coast
go over the speed hump using lebo angles. it wont scrape and will look fully sick uleh, and will also stop traffic, allowing everyone else to check out your hektik ride. chicks will also moisten up.
on a serious note, something must of changed to make your car hit. its either sitting lower, or you're going over the hump in a different spot that might be big enough to hit the chassis/undercarriage.
ari666
250,000 hits
greenacc
Searching for the billion
VE Berlina
Or the bump got taller ..
