jeffmills69
- Feb 10, 2017
- 94
- 8
- 8
- Location
- Melbourne
- 2011 VE Wagon
This all started around a month ago, thought I had a vacuum leak as fuel trims were high and had an intermittent rough idle, after using smoke to find a leak with no success I reset the ECM last week to reset the fuel trims just to have a suss on any other problems.. straight after doing this I got the fault code P0138 (Bank 1 sensor 2 high voltage) which went away after driving it for a day but just now I got a CEL for cylinder 5 misfire and it also was showing the stability assist had a fault and was turned off...
Would it be wise to first use a multimeter to test the supposedly faulty sensor or just replace both of the rear ones and start the car to see if it was just the sensor causing the issue?
