BANKS
DW I'm a Spray Painter!
- Aug 27, 2007
- 1,037
- 26
- 48
- Location
- Gold Coast QLD
- VZ SSZ Ute
Would it look crap without SS headlights you think?
EDIT: Just read you need projector lamps to use them, if I can find a set of ss headlights cheap then I might do this
You don’t need projector lights, but if you used them in non-projector headlights the cut off line and beam pattern wouldn’t be the same and it would blind everyone. I would only recommend doing this type of mod with cars that have the projector style headlights.
Personally, I think anything else but the SS lights would look crap. The way the LED parkers and the low beams flow would look 100 times better then non-projector style headlights.
I was having a detailed look at the headlights when I had them out. I found that the cut off line is actually achieved by a piece of metal shaped like the cut off line inside the bulb chamber. Sooo technically you could make you own cut off line, be it completely flat or just slightly angled. Would mean opening the headlights up thou. If I had a spare set lying around I would defiantly do it. But I don’t want to buy a set just to experiment on atm. happy with how they have turned out maybe in the future…
I saw a pair on ebay a week ago going for $400, which is pretty cheap
