BARINA TM DOOR TRIM REMOVAL
Chris Ikin
Oran Park
MY12 VE SII SV6
Hi Guys,
The misses car is having an issue with the front passenger side window not going up via the switch. Trying to take off the door trim and not having much luck. I removed the 2, 7mm bolts from the door lever and the door handle but can't find anymore and can't seem to pry the door trim off the frame. Does anyone know if there trick to removing the trim without damaging it.
Chris
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
Sometimes the trim is held on by ‘keyhole’ type clips. Try moving the trim about (up, down, sideways) and see if it moves.
