Barrel is busted
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by ascension24, Feb 7, 2007.
  1. ascension24
    ascension24 New Member
    My key wont turn in the barrell full stop. So does this mean I need a new barrell no questions asked? or are there some things I can try first?
    If i leave the key in the ignition I can hotwire and start the car, but the steering lock is on, how can I get the steering lock off so I can drive the car until I get a new barrel? thanks.
  2. Disturbed_vegeta
    Disturbed_vegeta I'd Prefer To ROAR!
    Burpengary
    Vs Statesman, Vr Senator 185I, Vs clubby, R32 GT-R
    well i sort of had the same problem but my key could turn but it wouldnt do nothing. so i tried takeing all the covers off and at the end of the barrel theres a black plug pluged into the end of the barrel, unplug it and there should be the other part bolted to the barrel. unscrew that(2 little flat head screws) then u could just plug it back in and then just turn the bit that was in the barrel with a screw driver..hope that makes sense(-%
  3. ascension24
    yeah, i have it all worked out.
    I ended up just wiring up the car with a push button start.
    You press the window lock button to turn the car on and the back window buttons to crank the car.
