Mopar
Hi guys, I know it's almost un-Australian to admit this, but I'm not a Holden guy! :hiding:
I'm into Valiants, do all my own work, and own a quick V8 Charger. I know my way around engines, just not V8 Holdens.
That said, my mate has a beautifully stock black VR Commodore S ute with a 304. He wants to liven it up a bit - keeping it completely stock looking - and so I'm going to help him get started. I've read a few threads on here, but don't have time to search for everything.
Firstly, can someone point me in the right direction to finding info on stock 304 injected engines so I know exactly what I'm dealing with: comp ratio, cam specs (flat tappet or roller?), ecu, injection and ignition etc.
For example, the engine has a dizzy - not coil packs - so does the ecu control the timing as well as the ignition and can both be remapped or not? If not, do we need a plug-in chip or can the stock ecu be reflashed?
We're going to start with new dizzy cap, rotor, coil, leads and plugs. OEM or are there better suggestions? Best plugs/gaps for these engines? Best coil?
Is there a good after-market snorkel for the VR, or would something from another model fit? The air intake/snorkel is tiny on this engine. We'll be running a K&N filter and stock TB. Prefer to leave it looking stock.
Injectors: the engine has 150,000km - are there good, cheap replacement injectors for VR 304s? I read somewhere about using VT injectors - what size/colour for a basically stock, tuned 304?
Once the ignition and intake are taken care of, we'll be upgrading to a 3" single exhaust, hi-flow cats and likely Pacemaker headers (other suggestions?).
And once all THAT is done, it will be time for a tune. Good tuners in Perth?
Eventually we'll be pulling the heads to clean them up, replace the valves, springs, seals etc, and may then upgrade to a a small flat-tappet hydraulic cam. But that's down the track.
The idea is to freshen the ignition and get the engine breathing better to improve power and economy, but leave the car looking stock. This is a work ute, so any head work/cam/compression changes will be aimed at keeping her streetable but snappy.
Any other ideas on how to improve the engine that haven't been mentioned?
Thanks for helping a Mopar guy! (But you'll really be helping another Holden fanatic.)
