So the over the rad cai is no gain what soever over the little straight bit that came out standard?
MAF sensor - so it's a roller motor? Even better! (No wonder it's quiet.) Still the same 8.5:1 compression, or slightly higher? My XR8 runs 9.4:1 with iron heads and hydraulic roller cam, and E10 works a treat. (The Charger is 11.4:1 with alloy heads - but that's another story!)
Cap and rotor as originally mentioned.
Bosch coil.
I, too, like NGK plugs - .035" gaps sound right?
What do you think of a 3" single system and muffler stepped down to 2.5" over the diff? That's what I've done with the Charger (twin 3" into 2.5") to quieten it down - but still have the advantage of removing the tail pipes and freeing up the exhaust for down the drags.
Champion iridium are the best plug by fair margin run em in my 304 but not a 304 now but top plugBeing a series III it may have a roller cam motor then instead of flat tappet.
Does it have a MAF (mass aif flow sensor) connected to the throttle body piping?
Or does it have a MAP Sensor on the firewall near the build plate?
if it has a MAF, its the newer roller motor.
There was an SS inductions otr for the 304 many moons ago, if you can find one second hand they are ok but not great, and very expensive....may as well just keep the stock intake with a good filter if you want it stock.
I prefer a 2.5" to a 3", the main reason is a single 3" is going to be pretty damn loud, and there is always the chance of exhaust drone then.....2.5" is the sweet spot I reckon, but if your going with a bigger cam etc 3" would be better performance wise.
Most tuners will tune a 304 for 98, but I am sure you could change that upon request. (I have never seen a 304 tuned on anything other than 98 so I can't really give an opinion here)
As for leads, it depends how much you want to spend....I do like ICE leads, but they aren't cheap. (just running eagle 8mm's at the moment with no issues)
As for plugs, the standard $4 NGK-R plugs will do the job just fine (I swear by NGK, but bosch would be fine too, just don't use champion, for some reason the 304's just don't seem to play nicely with them).
On these motors the standard Bosch coil and dizzy are good for up to 450-500hp so no point changing, I would just replace the cap and rotor for good measure.
