Battery Drain Issues..
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by HektikStrapz, Mar 22, 2014.
  1. HektikStrapz
    HektikStrapz New Member
    Queensland
    2007 SVZ Ute
    Hey guys,
    Battery keeps going flat in my 2007 SVZ ute, I went for a drive the other day, started fine when i first hopped in, drove for about... 10 minutes, pulled up, car wouldnt start, crank once or twice, that was about it, then i drove about 40k, left the car for about 2 hours, and it started fine, ran fine, then drove around town and 40k home (i live out of town) so it got a decent run, i didn't drive yesterday but i hopped in today to move it out of the shed, same thing, cranked once then the starter just clicked, i'm fairly certain it's not the alternator but i haven't pulled the positive off while it's running to check, mainly because it charged my battery while i was driving around town
    Has anyone else had this issue? my friend thinks it could be a 'dying cell' in my battery? (i wouldn't have the faintest clue about batteries) my car gets locked every night and the keys come out of it because my door locks like to have their own mind, so nothing is left on in the car.. starting to get a little fed up with it, i never had this much trouble with my good ol' ecotec
  2. illlusion
    illlusion Member
    VE SSV MY10
    sounds like the battery its self get a new battery never pull the battery off when the car is running as it will stuff the diodes up in the alternator get a multi meter to test the alt output
  3. Big-Al
    Big-Al Banned
    Aussie and proud
    VY SS 5.7 M6
    sounds like the battery is on the way out. the alarm draws a small amount of power constantly when the car is parked. probably draw enough to flatten enough to not be able to strart it.
    Try a known good battery and see if the issue remains.
  4. HektikStrapz
    Queensland
    2007 SVZ Ute
    Cheers fellas, will invest in a new battery and see how that goes
  5. Big-Al
    Big-Al Banned
    Aussie and proud
    VY SS 5.7 M6
    also check that the light in the glove box is actually switching off when you close it.
  6. DeanoV6
    DeanoV6 Member
    VZ Executive
    Neighbors VT would start no problem when cold but if he tried to start it when the motor was hot all he got was a starter motor click. replaced battery - No difference, New starter motor fixed the problem
  7. XUV
    XUV Member
    HSV XUV
    Check the voltage when stopped ,
    If it's above 12.1 it's still good cell wise and might just need a good charge from a battery charger to put things back in order.
    If it's below 12.1 , give it a charge and see where it sits after charge, above 12.1 good, below 12.1 no good replace.
    My projecta charger will flash after a charging session if battery is faulty.
  8. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    Have you checked to see if the battery terminals are clean and tight?
    Take them off and check the inside of the terminals....see if they're clean.
    Also check the battery posts are clean.
