battery draining
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by staceylee, Jul 4, 2012.
  1. staceylee
    staceylee New Member
    brisbane
    VT commodore
    I recently replaced the fan belt tensioner as it was quite loose and not catching on to start the car up all the time, we were dealing with this problem for about 2 weeks. Now it seems it still isnt starting when its really cold but if we put a fully charged battery on it would start up. the thing is once we do this we will drive about 10 mins away to work then come back 8 hours later and the battery is flat. what could be causing the battery to drain so quickly while the car is off and sitting when it was fully charged?
    dodgy battery?
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    It could be the battery. It could also be a short somewhere causing the battery to go flat. I'd fit a new battery first.
  3. itsagixa
    itsagixa New Member
    VX SS
    Check the battery voltage when the car is running, it should be 13-14v if it's like 12-11v then the alternator isn't charging it.
    If you have access to a clamp meter, test the current draw on the battery with the car and ignition completely off, there should be no/minimal draw current wisr
  4. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Any electronics unknowingly left on. I'm at Tafe and just competed the battery test
  5. itsagixa
    itsagixa New Member
    VX SS
    ^^^^that would of been a 10 minute course yeah?
    I used to work for Century Batteries doing UPS and solar systems for Telstra and huge data recovery centres.....want to know the best bit of advice about a battery?
    The heavier it is the better it is (in about 90% of applications due to the higher lead content) unless its a AGM
  6. c2105026
    c2105026 Active Member
    NSW
    2000 VTII Commodore Olympic, 2012 Ford Focus ST
    re: new battery - choose one with highest CCA as possible. I had a 2005 Corolla that I fitted a big stereo to. Drained the battery on more than one occasion just sitting there listening to stereo, car not running. Battery place fit a battery from a subaru wrx, and made up a new support base for nix. More CCA= end of flat batteries.
  7. FATMOE
    FATMOE New Member
    VY Clubsport R8
    If your gonna sit in your car pumping your stereo up while the car is not running, it will benefit more from a deep cycle battery with a higher reserve capacity rather than cold cranking amps.
  8. c2105026
    NSW
    are not the two related? did fix the problem.....
  9. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    I always get the highest CCA rating I can when buying new batteries. Ive got a 600 CCA in my VSV6 at the moment. It was the highest CCA rated battery in stock that would fit in the car.. It was minus 4 degrees below 0 here this morning, and you need a bloody good battery on heaps cold mornings like these.
