Hobojo
- Mar 30, 2014
- 5
- 0
- 0
- Location
- Melbourne
- VY Coomodore Acclaim
First my ABS unit started playing up... Alarm went off, light went off and dash instruments cut out intermittently. Disconnected the ABS which stopped dash instrument cut outs. Now I am finding that the battery is going flat after 24-48 hours. :lock: Checked the current draw on the battery with a multimeter and found a 40 mA drain which intermittently drops to 2 mA after a short time. Tried pulling each fuse and relay but the draw did not change. Firstly is a 40 mA drain normal and secondly, what else could be causing the drain if not found by pulling the fuses and relays. I have also noticed each time the battery is initially connected, the antenna goes up and down. Have thought maybe the alternator is causing it but it charges the battery once the engine is running. Checked if the interior lights, boot light and glove box light are causing it but don't think so. Any ideas?
