dv81
hi all i have fitted a vq 5l and t700 into my hz tonner all was working fine until i was setting up my temp gauge i had to change the temp sender to suit my gauge and i have done this but in doing this the wire in the engine harness i was testing to see if it was connected to my gauge already as i had a work shop fit the engine and in doing so i hit the positive side if the battery and it sparked out and the was a noise from in the dash area near the gauges and now the battery light and engine light are on contantly and the revs are high around 1500 when in park and 1200 when under load it also smells like its over fueling it has all the hz gauges still except the fuel gauge and im not sure if i can check for fault codes with this set up any help would be great
