naf33n
go
- Feb 25, 2006
- 1,243
- 20
- 38
- Location
- The Shire
- Supercharged VU SS
there a heaps of ways of doing it. you can use an isolator switch, which are usually bigger and bulkier.... or a solinoid which is just a big relay and have a small switch mounted on the dash somewhere,
probably the easiest would be using a 'trickle' or 'float' charger which are small automatic chargers, wire up a small plug some where under the front bumper, that way you just plug the car in if you think it will be sitting around for a while
battery isolator\
http://www.google.com.au/imgres?imgurl=http://www.smartmarine.co.nz/images/large/battery%2520isolator%2520switch%2520aaa.jpg&imgrefurl=http://www.smartmarine.co.nz/battery-isolator-switch-with-removable-capped-key12v-p-524.html&usg=__zx-VrA3hChHwPV9Zaz8_VEhQl24=&h=377&w=453&sz=27&hl=en&start=28&zoom=0&tbnid=fkpjY39fZ38ECM:&tbnh=106&tbnw=127&ei=TkmITbqHJIG6ugOA84jhDg&prev=/images%3Fq%3Dbattery%2Bisolator%2Bswitch%26um%3D1%26hl%3Den%26sa%3DN%26biw%3D1419%26bih%3D730%26tbs%3Disch:1&um=1&itbs=1&iact=rc&dur=390&oei=TUmITfjiDonYuAOK2bSgDg&page=2&ndsp=30&ved=1t:429,r:26,s:28&tx=65&ty=69
battery solenoid
http://www.google.com.au/imgres?imgurl=http://i184.photobucket.com/albums/x104/sidewinderdotcomdotau/solenoid/ABR-Solenoid.jpg%3Ft%3D1255587819&imgrefurl=http://www.sidewinder.com.au/page81.html&usg=__4eKz61BfaMpFYSuA68mTQ5jzH9E=&h=311&w=400&sz=21&hl=en&start=0&zoom=1&tbnid=lNvSXI6vE_ja0M:&tbnh=137&tbnw=174&ei=pEmITYDYDYbUvQLWQDg&prev=/images%3Fq%3Dbattery%2Bsolenoid%26um%3D1%26hl%3Den%26sa%3DN%26biw%3D1419%26bih%3D730%26output%3Dimages_json%26tbs%3Disch:1&um=1&itbs=1&iact=hc&vpx=1138&vpy=75&dur=125&hovh=198&hovw=255&tx=147&ty=118&oei=u0mITY6KB4-WvAO4t5mCDg&page=1&ndsp=28&ved=1t:429,r:6,s:0
battery isolator\
battery solenoid
