statowl
Hi guys. I've been lurking on these forums for awhile,and have found answers to all my questions till now.
My car is a 2004 wl stato 5.7 :driving: and nearly 300 thou on the clock .
Problem is the battery voltage is down to 12.2volts by the morning when my car is sitting over night. and when i go to start it in the morning i hear a tick when i
turn the key. Some times it will start on the second key turn but usually on the 3rd or 4th key turn. Once the car has started, it is good for the rest of the day.
While Driving my voltage is around 13.8 to 14.2 volts.
This has been going on for about a week or so.
When i turn my car off i check the voltage on the cluster and the voltage is at 14.
Aftermarket accessories are 1 audio amp, capacitor, speakers, cd player and a roof dvd, 7 pin trailer plug and an 50amp anderson plug.
I've already had the sticky indicator and replaced the relay for it last year.
My key has a new battery and the ignition barrel has also just been replaced.
So far I've replaced my car battery with a new 620 cca century battery, cleaned both terminals, bought a good multimeter and preformed a drain test.
I have a drain of 00.02 ma. i pulled all the fuses one by one under the steering wheel and under the bonnet.
when i pulled the lighting f/l fuse under the bonnet the drain went to 00.01ma
when i pulled the main fuse drain went to 00.00ma.
i also tested between the battery and the starter motor on its own and it had a drain of 00.02ma.
There is no drain on the anderson plug.
Any ideas what could be going on?
Is there anything else connected to the wire that goes to the starter motor from the battery?
What is the lighting f/l fuse under the bonnet for?
what should the standard ma drain be on the car?
Thanks for any help.
