BCM and Power Windows
breast69au
40
VY Executive
Has anymore installed power windows in to there VY Commodore and if you have have you needed to replace the BCM with a upper model one and which pins do you connect the power windows up to, to get it going to holden specs??
Cobra30
www.cobra30.com
VY V6 S2 Crewman
I've fitted power windows to my Crewman. It already had the wiring in place. I had to change my 'LOW' BCM to a 'MID' level BCM, have it programmed to the car and also purchase new remotes and have them programmed.
There's a bit more info here
Have you checked to see if the wiring is already in place - see if the switch connector is under the console ?
breast69au
40
VY Executive
when you pulled your centre console out was it just sitting there or did you have to look for it, cause i have my centre console out and i cant see anything there. i looked in my fuse and the fuse and relay connectors are there with power
The Other thing is do you know which pin outs of the BCM are hooked up to the power windows
