nitrowarrior
- Aug 12, 2009
- 160
- 1
- 0
- Location
- East Gippsland
- 1997 Vt GTS Build 78
How do I figure this pickle out..................
HSV model have an Security system intergrated into the loom.......
IF I?????????
Remove the HSV computer.......
So remove ECU, BCM, PCM?.................. replace components..........remove all link backs from ecu loom/bcm loom for the ISS....
Install HSV Memcal in replacement SS 5.0litre ECU, PCM?, BCM.. Link all units with TECH2...Programme New Key Head......
Will this work.....and make the VT HSV work with out being asked for ISS security Tags............
Worst I can figure it will do is store the VIN/Hardware Code of the donor vehicle.....................Is this the only issue.........
Series 1 HSV GTS...What BCM would I need.....Mid? High? does the number on the BCM matter of just luxury level?
Do i have to use a Series 1 BCM,,,,or can I use a VT series 2 or later BCM for donor part?
Hopefully my questions are all on point.....sorry to bombard but am stuck.....
IF I?????????
