Trevor loves holden.
- Jun 6, 2019
- 3,508
- 750
- 113
- Location
- Victoria
- vs commodore
Would recommend a Auto Electrician a Mechanic wont solve electrical problems, Burnt out relays would suggest short in wiring or a spike in voltage, even a jumpstart done the wrong way, I say you need to have your wires tested to the fuse box for any damage u can do it with a multimeter to test from one side of the + wire to the other side using neg from battery to + wire on either end to see voltage at either end to see if its the same, also earth test the same way but using + on the battery. ( hope that makes since)
any plastic or rubber will be ok to use a non-conductor wouldn't use wood it will break down after tighten it even crack off. A old bike tube or tyre without wire will do, Clark rubber has plenty of rubber grommets.
