BCM not communicating
StephenM
71
Innot Hot Springs Qld. 4872
VS Equippe Series II
I have brought this up before. BCM will not communicate through the OBD port. I checked current and continuity so the wiring from port to BCM seems OK. 12v from power (16) and 5.5v from the BCM. Good earth continuity. However there is only one earth on the port. Every thing I have seen says two. My research suggest a faulty BCM (Snap on Tools documentation). If I get a new BCM does the kay have to be programmed to it or does the key programme to the PCM? The car is running a bit rich and occassional stalls at low revs. I have earthed BCM as suggested inother threads re running rich. Many thanks, Steve
woteva
NEED 4 SPEED
Adelaide S.A.
What are you connecting to the port ?
You will need an ALDL interface as the VR/VS do not use OBD 1 or 2 protocol.
BlackVXGTS
Melbourne, SE
Have you diagnosed using the tried and true "paper clip" method? Also check out the attached pdf files.
  • Chart A V6 PCM On Board Diagnostic System Check.pdf
  • Chart A-1 V6 PCM No Check Powertrain Lamp.pdf
  • Chart A-2 V6 PCM No Serial Data, Will Not Flash DTC12.pdf
StephenM
71
