Bcm removal?
lout
60
Langwarrin Victoria
disconnect battery
remove panel under steering wheel
unplug bcm
remove bcm
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Mine is behind the fuse board .looks like i have 2 remove it?
Once that panel is removed (lout mentioned) the bcm just pulls down.
You will have to take the plugs of first before the bcm will come completely out.
danoz vt vz
46
casino
vt 2000 wagon ve omega sportswagon
Lads that was a terrible effort of telling the lad how 2 do it.He knows he needs the box moved location of screws or techniques would of been good.Also does the bcm clip in and does it need to be pulled or slid left or right or there any tangs that have to be pressed for removal.People usually arrive here cause they are stuck the fastest easiest most informed way of doing this helps beyond belief.Or anything.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
An old post I know, but for future reference you push the bottom of the BCM forward (towards the front of the car) to disengage the clips, then pull the BCM down.
No need to remove the fuse panel, just reach up behind it. A bit awkward but doable.
Fu Manchu
WA.
Can confirm. You get upside down in the foot well and do as above. Takes a minute or so to do.
lout
60
Langwarrin Victoria
almost as helpful as your post
lout
60
Langwarrin Victoria
deleted
