hi does anyone have wiring diagrams for all low, mid, lux and high series bcms in the vs model, may put a mid or high or lux bcm in and want to make a adaptor harness and really need the diagrams
These might be of some help to you.Im not too sure about which models they are for though.I know my VS exec has a low 150 BCM. When I programmed a new ignition key a couple of months ago, the new key I bought from ebay had the 3 buttons instead of 2. After I programmed it, I checked it was working correctly with the tech1, and I noticed that the low series BCM can detect when the boot button is pressed, it shows up on the tech1 as "Trunk" when its pressed, so the low BCM can definitely detect that the boot button is being pressed. What I'd like to know now is if the low BCM's have an output pin in the connectors for the boot release like on the higher BCMs. I wouldnt have thought that the low BCM's would even be able to detect that the boot button on the key is being pressed..
As far as I know this is to disable the alarm so the boot can be open without unlocking the whole car
