Bellmouth problems
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Gudgeon, Jul 16, 2008.
  1. Gudgeon
    Gudgeon NE1 4SX
    Mount Gambier
    VR Exec S2 and VK 333 Pack Calais
    I have a VR s2 exec. i read on a post about bell mouths and decided to see wot all the fuss is about... turns out its nothing. the car idle roughly. so i put it back in and the car still idle roughly on start up, i hold it at 3000rpm for 8 seconds and the idle returns to normal, but the engine light is on. is this just that it's logged a fault code?? if so can i retreive codes with out a computer?
    the problem of rough idle starts again once the key has been cycled. any ideas??
  2. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    did you disconnect the ecu for a few seconds before you did the rev at 3000rpm thing for it to reset the idle. If you didnt then what you did will do nothing, and yes you can retreive them simply do a search on codes and you will find the how-to thread
  3. Gudgeon
    Gudgeon NE1 4SX
    Mount Gambier
    na.. thanks. that'd be wot im missing i reckon
  4. Gudgeon
    Gudgeon NE1 4SX
    Mount Gambier
    i disconnected ecu, redid the rev to 3000 thing. still getting the same problem with engine light on. i checked the codes and getting code 33, which i think is MAP sensor voltage to high..
  5. Cheap6
    Cheap6 New Member
    VP Exec
    I would say that you haven't reconnected one of the vacuum hoses, perhaps the one to the MAP sensor, or perhaps the gaskets between the inlet manifold and T'body elbow are no longer sealing after being removed and refitted.
  6. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    Yeap Cheap6 is on a winner there!
  7. kopper69
    kopper69 New Member
    VRII Acclaim
    With guys above, double check your work. Hoses loose or cracked, gaskets that may have to be replaced. Sensors disconnected. Check especially around the back of the throttle body.
  8. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    I did the exact same thing last week when I cleaned my throttlebody. Make sure the hose that comes out the back (towards the rear of the car) of the throttlebody is in place, it goes about a foot over towards the passenger side and into a small black box on the firewall.
