bellmouth
Discussion in 'General' started by executive_power, Jul 27, 2006.
  1. executive_power
    executive_power New Member
    hello does anyone know if taking out ur bellmouth inside ur inlet manifold changes ur fuel economy?
  2. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    Shouldnt make a difference. Idle will be a bit rougher though, the bellmouth is designed to spread air flow more evenly across the cylinders and give a smoother idle after the rough VN S1 engine.
  3. Morton
    Morton For external use only
    Fairstar the Funship
    I took my bellmouth out, and noticed no difference to fuel economy, some difference to throttle response, and marginal difference to the idle. It's a commodore anyway, try and forget about fuel and just enjoy it ^^
  4. semi
    semi GOD
    WA
    VR exec wagon
    i barely notice any difference in idle, but slightly better throttle response. However i did a bit of a service at the same time, so that might change things
