Belts??
lwessel
sydney
VR Statesman sII 5ltr 1995 & VE SS V8 Commodore
Hi all i have these 3 Belts 1 is freyed and 1 looks like its about to snap the other looks ok but before i try and take out anyone can tell me sizes and name??
I have a VR Statesman 5ltr 1995 model..... cheers
BlackVXGTS
Melbourne, SE
If it's just a standard VR V8 then 11A1130 can be used for both the alternator and power steering belts. You should only need 11A1145 if you have a 120amp alternator installed (standard is an 85amp alternator). Also, if you use the later model double waterpump pulley where the belt goes from the crankshaft -> power steering -> water pump -> crankshaft, you need a longer belt but I can't remember the number.
lwessel
sydney
I'll check tomorra and flick you some better pics of area ✌
