Best Injector Replacement for a VN
dvspcs
I'm doing some work on my sons VN Calias and have found one of the injectors are stuffed so I'm going to get a set of Reco Injectors, what model injectors would be the best.
VN,VR or VS
are they a direct swap or whould I run into problems
xcop5l
4th year spanner spinner
ol' geelong vic
VN ex cop 5L
there a basic swap but use silicone spray or similar on the o rings coz they can grab and tear then youve got a leak
dvspcs
so the VS would be OK or just go for the VR one's
glowworm
vt exective
vn to vs are all the same VT are not they are different ..glow
FXST01
The Grey Man
Perth, WA
VP V6 Exec
VN series 1, 8-88 to 10-90 uses injector number 0280-150-901 which flows 146.3 GPM @ 3 BAR. Resistance 14.5 Ω.
VN series 2, 11-90 to 10-91 uses injector number 028-0150-960 which flows 150.5 GPM @ 3 BAR. Resistance 14.5 Ω.
These injectors are also fitted in the
VG UTE 11-90 to 10-91, VP COMMODORE 11-91 to 07-93 and the VR COMMODORE 06-93 to 04-95.
VT - VY N/A, 09-97 to 06-03, uses injector number 0280-155-777 which flows 150 GPM @ 3.5 BAR. Resistance 12 Ω.
The VN - VR injectors are what is classed as an EV-1 injector pintle type which are open to problems when used at an incorrect fuel pressure, hosing is a problem if pressure is too low or too high and the pattern can also be forced too wide for the target area if pressure is too high.
VT - VY injectors are what is classed as an EV-6 injector which uses a multi orifice director plate style technology to better atomise fuel across various operating pressures. These injectors allow more flexibility in relation to operating pressures without compromising spray efficiency or fuel atomisation.
