Best leads for Vr V6?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by dk4400, Jul 20, 2010.
  1. dk4400
    dk4400 New Member
    HERVEY BAY
    2008 VE SV6 UTE
    I need to replace the leads on my VR v6, it is a bit worked with a big cam, ported and polished heads etc, Im not sure what brand is the better and what size should I go for 8mm, 8.8mm?
    Any suggestions would be great :)
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Unless you are running forced induction or really stupid high compression, a lead is a lead. Doesn't matter what you use.
  3. RX25SE
    RX25SE Real cars are steel cars.
    MY07 Liberty 30R Spec B 6sp wagon
    As above, stock leads would be fine.
    I alway use genuine Holden. Not much dearer than aftermarket and come with new metal ends.
  4. dk4400
    dk4400 New Member
    HERVEY BAY
    2008 VE SV6 UTE
    Thanks for that, was thinking of going for a set of TopGun 8mm leads with the heat sheilds, around $85 from local Autopro.
  5. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    As every one has said don't bother. No difference on a stock car.
  6. slayer208
    slayer208 New Member
    Tasmania
    VS-II Esteem
    I've always used Bosch performance leads and have found them to be reliable. Also, I think there may be a little to gain by using performance plugs such as Bosch super 4's. Maybe those iridium type might be okay. I know they're much longer lasting than standard ones.
  7. hendorockstar
    hendorockstar New Member
    SE Melb
    Blown 5l VS Calais
    Yeah mate stock leads are fine, don't forget to change your plugs though
  8. greenacc
    greenacc Searching for the billion
    VE Berlina
    Don't bother with Magnecor either, they are supposed to be good for hi temperature, but i managed to melt the boots on track day.
    Genuine are good leads mate, and the heat sheilds actually fit properly so they last for ages.
  9. dk4400
    dk4400 New Member
    HERVEY BAY
    2008 VE SV6 UTE
    Cheers for that, I got some TopGun 8mm leads with new heat shields as well, the old ones didn't have heat shields on them at all,
    seems to have made a difference its idling a bit smoother, plugs where changed not long ago ( 1 month ) so left them in.
    Still need to look at the oxygen sensor yet.
  10. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    i am using top gun ones to
  11. Stokesy VS
    Stokesy VS New Member
    Laurieton NSW
    Commodore VS series 2 S pack
    i have top gun 10mm leads and they work a beauty around 120$ and they just give really good throttle response and somewhat better fuel economy
  12. dk4400
    dk4400 New Member
    HERVEY BAY
    2008 VE SV6 UTE
    I wasnt sure about the 10mm ones, thought they might have been to big, but the 8mm seem to be ok, my motor is worked a bit and perhaps should have gone bigger leads.
