best place to buy hydratrak diff oil
shanhsv
Luvo
Muswellbrook, NSW
VSII Calais V6 & VSII Senator 215i
I just bought a new diff for my senator and before i put it in i want to change the oil. Supercheap werent helpful and i know holden will charge me an arm and leg. And yes i know this sh!t is expencive as it is
Immortality
Staff member
Sth Auck, NZ
You'll need to figure out what the correct grade/type of oil is required and then track down a supplier.
shanhsv
Luvo
Muswellbrook, NSW
Because its not a regular diff. The way the lsd works is completely different and needs special oil
BlackVXGTS
Melbourne, SE
Hydratrak uses a special viscous coupling cartridge to perform the LSD function - this cannot be serviced and must be replaced as a unit. Rear axle oil is a standard synthetic hypoid gear oil to HN2040 standard - Castrol SAF/XA, Mobilube SHC 80W-140 ID and others.
SweetWagon
booosted
35
Springwood NSW
VS Berlina Wagon Supercharged
Yes I know this, but as above the Hydratrak itself is a sealed unit, therefore don't see why the rest of the diff would need a different oil
Harvs82
41
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
Castrol SYNTRAX 80W 140 as listed on their lube match system... 1.7 litres capacity
