Bizmark
Ok i i changed my coolant in my V6 VR a few months ago as a mechanic recommended it, since then i've been having airlock problems in my coolant, the water will get halfway to H and engage the thermo even when cruising along the freeway. Before dropping the coolant the car was almost always on 2nd mark from cold (1/4 way to H) and never went much over that.
I tried to fix the problem by cracking open the bleed screw on the thermo housing after a drive and letting some air/coolant out until it appeared nothing was coming out. Did that many times and no improvement in my cooling problems.
Did a full cooling system flush late last week and i'm still having the same problems. There seems to be a heap of air in the system this time as well. I've tried to bleed the car while cold by jamming a coolant bottle into the radiator cap and cracking the bleed screw open. It seemed to push out a lot of air but it definitely hasnt got it all.
Whats the best way to finally get rid of ALL the air in my coolant? Been having this problem for months and its really starting to annoy me.
