Bi-modal Rear mufflers - only one outlet black
MY17DIR
42
Gods Country, NSW
MY17 LE Director....
Has anyone else noticed how black the inner outlet with the bi-modal actuator/flapper on each muffler gets really black and each outer one stays really clean?
For reference, relay is pulled so bi-modal flapper is always open. Would have though both would then be the same colour...
3rspecB
VF2 SSv Redline, White Manual Sedan
When in open position, all the exhaust gas flows out the inner tip which has the bimodal flap.
abuch47
Madelaide
LSS3 YOOTE
Meant to ask this 6 months ago, especially worse after changing the centre to flow better.
MY17DIR
42
Gods Country, NSW
Righto, that makes sense then. So single outlet really then :(
Anthony121
VF SSV Redline MY17 & VF Director
Take the relay out then the valve stays open all the time :)
Jackv8
37
Gold Coast
2012 SS-V II
And get the relay-tap remote off ebay
Is there a option to connect a switch and wire to the factory bi modal relay/fuse to control the on/off state?
