[Ecotec] Big charger for the l67 2lt m122,,
allchargedup
Warragul
VE GTS
New charger for the l67,,,
2lt m122 or 2.3 tvs
First install vx belina
m122 bolt on only mods
electronic automotive dyno tune
Wednesday 15 will post final dyno number as soon as i get it .
car ran 233kw dyno vids on youtube
m122 charged l67 v6 dyno
_R_J_K_
Zenki S14
Did you use a kit or did you fab the manifold and parts to suit yourself?
chargedvx6
VY SII HBD Calais L67
How many kg is it?
allchargedup
Warragul
VE GTS
Ok hear we go I will be ending the non intercooled unit intercooled only just to unsafe never tested it or wish to
don't believe in no Intercooler hear is a price run down on m90,,
Intermediate Intercooler $1970
boost pulley upgrade $165
69mm thottle body $232
the easy stuff total. $2367
Then next level
charger porting light weight rotors
will set you back. around $1450
overdrive 8 rib kit $430
that will get you about 180kw,atw
total so far. $4247
Thats the cheap stuff now brand name
yella terra Intermediate kit $4037
whipple kit suit l67 $6500
side mount $5964
Now my kit bang for buck stuff will only get u so far this is for people who want big power with top mount charger. And I need to make something or not worth doing.
the time money stress that whent into this product was massive. The way I figure i fit in the middle but can make massive power
The kit is easy to install.
made it as unaversel as i can and perform 233kw boltons only.
I must say i do miss that m90 wine.
this one you will never spin fast enough 86mm pulley is good for
12 to 16 pound depends on thottle body. ported l67 one holds it back
This is the next power level product.
all made in Australia local people
will never go overseas to save a buck
And now back to power
next is a built l67 on e85 going for
300kw atw
also by no means do I want to turn this forum into a war with dyno nubers or turbo can do this m90 people will stay with m90 turbocharged people will stay turbo people
your car your choice
_R_J_K_
Zenki S14
Bit rich for an adaptor and couple bits and pieces imo.
Can buy the charger for less than this kit lol.
Don't get me wrong it looks good but that's big $$$ for what u get.
Not really. I''m aware of one M122 setup in Canberra that uses a modified L67 manifold, and for the amount of labour and custom work that was put into developing and installing that kit, this is cheap as chips, particularly as it's billet.
OP, do you have any pictures of the fuel rail and injector setup?
allchargedup
Warragul
VE GTS
Fuel rails under revision just to many fittings new system just plug in existing l67 fuel lines and use your factory fuel pressure reg
Why the charers are cheap this kit makes sence. Hitting the 230kw gave me a hole new drive.if i can make it perfect i will If the m122 becomes to dear i will run 1.9 tvs
allchargedup
Warragul
VE GTS
Only came on hear to get the product out there. This is only one of many.Last 18 months bean involved in product development
I have more to come
The next product line will blow your mind no won will believe the numbers stay tuned.
Only done the kit for the l67 because I have a bit of a soft spot for them I personally have a 4.2 built l67 m122 charged in my
off-road toy insane power for a single cab hilux that doesn't handle or stop.It wonts to kill me every time i drive it lol
allchargedup
Warragul
VE GTS
Dyno vids on YouTube
m122 charged l67 v6
There is 3 of them
Electronic Automotive Epping Victora Maffless Tune
Highly recommend them for delco tuning great to deal with.
Other people who helped make this kit happen
Casey Automotive Vic
Motorsport Depot Vic
Thankyou for your help getting it done right. And to the people taking time to read this.
