Bigger throttle body questions
phatvtcom
south east melbourne
'99 VT
Just have a couple questions about upgrading to a bigger throttle body for more air intake.
1. Does it make a big difference in performance and is it worth it?
2. Is it fuel efficient or completely opposite?
3. Are there other parts that would also need to be changed?
thanks.
johnvtls1
Melton,Victoria
E92 BWM 335I
NO JUST A BIT MORE THROTTLE RESPONSE
SHOULDNT CHANGE TO MUCH
IF YOUR CARS AUTO THEN THE TUNE NEEDS TO BE ADJUSTED AS THE TB STUFFS UP YOU SHIFT POINTS. HOPE THAT HELPS
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
thanks.
This is what ive heard from others, not personal experience
1. It makes a slight differnce with trottle response is more effective if u have done some other good mods also works much better with a tune
2. I wud think yes and no if u plant it alot more air = more fuel but if ur driving normally maybe better or the same fuel economy
3. No its just a simple take other TB off and install new one
PS the other lad beat me to it
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
You sure about the stuffing up the shift points part? i asked mace about putting a bigger tb on my auto he said it will be fine and it wont need a tune
johnvtls1
Melton,Victoria
E92 BWM 335I
yeh, when i put one on my VS it stuffed up the shift points pretty bad. It shifted really early and made it pretty average to drive.
VTmadS1
VT Executive S1
yeah i've got one in my VT and the shift points are now stuffed, however the throttle response is noticeably better with the modifications i have.
