vc commodore
- Jun 18, 2014
- 10,715
- 12,606
- 113
- Location
- Like the Leyland Brothers
- VC, VH and VY
”Compliance“ means the ability to absorb bumps. If I meant that the tyre would be leaving the road I would have said “Conformance” which means contact with the road (grip).
Agreed. These bumps that aren’t absorbed by your tyres and now absorbed by your suspension, increasing the wear on those components.
Incorrect. If you could hypothetically put a one metre wide tyre on the front end of any car and turned the steering wheel the inside or outside of the tyre will lift completely off the ground purely based on the kingpin inclination angle. The scrub radius also loads up the tyres more the further away from the pivot point that part of the contact patch is.
This is an extreme example yes but these forces are still in play on any vehicle just to varying degrees depending on the wheels and tyres fitted and the suspension geometry.
I‘m quite sure that certain things can be done from an alignment perspective to improve the situation but most wheel aligners will just bang on the factory specs regardless. Also certain parts of the suspension geometry aren’t adjustable, so there’s that.
I wouldn’t say that going from 205 to 225 was a massive width change TBH and you still have decent compliance with a 50 profile but the fact of the matter is your tyre mileage would be better with the factory 205/60R15s. What I’m talking about is using ultra wide and low profile tyres (30 profile etc), especially on the fronts.
My “10,000kms” wasn’t a hard and fast rule, I’m just saying tyre longevity is compromised by using a wider and lower profile tyre, this is just a fact. Your example of 30,000 to 35,000 I would be unimpressed with myself and I would see it as being on the low side but the lowered suspension wouldn‘t help with that and driving style and patterns (highway, city, winding roads etc) vary the mileage considerably as well.
I’ve owned two VH commodores before with stock tyres and suspension and they were diabolical especially in the wet! I never had the money to change them out to better suspension and bigger wheels and tyres but if I would of had the money I would have in a heartbeat and screw the extra tyre wear as they were scary in the wet.
Tyre profile job isn't to keep the tread planted on the road surface....That's the shock absorbers job.
Front suspension on the VB to VP is identical.
Maximum tyre size from the factory on a VB is a 205/60X15
Maximum tyre from the factory for a VP is 235/45X17
So you are saying if I put a 235/45X17 on a VB, I will get less mileage than what I would with a VP
Front suspension design on a VR to VF is identical (yes minor differences, but the basic design is the same)
Maximum tyre size from the factory for a VR is a 235/40X18 (might be wrong)
Maximum from the factory on the front of a Vf is 245/40X20
So if I was to put a 245/40X20 on a VS, I'll get less mileage than what I'd get from the VF?
You mention factory specs again...Did you know there is a scope within those specs? Not 100% sure of the scope, but it's where you set the settings determines the wear on the tyres....eg, say the scope for camber is 1/2 degree positive to 1 degree negative....That is a big variation, so what do you say is the best setting to have to stop tyre wear?
Toe specs...Say they are from 6mm toe out to 6 mm toe in...Where do you set it? You can't have them as variable once set
Wear on components is another factor, but that's another area which isn't worth going into.....Same applies with pressures....The topic at hand is tyre sizing and honestly, width has nothing to do with accelerated wear
