black sooty lookin exhaust tip
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by muzza, Sep 29, 2008.
  1. muzza
    muzza New Member
    gladstone
    vx berlina
    hi guys on a v6 vs with 220 000 km on it i have on the last 1 or 2 cm of the standard exhaust end black sooty lookin residue would this just b normal or mayb runnin rich the o2 sensors r original and 1 also suspect its usin a bit more fuel than it should cheers
  2. hsvpunk
    hsvpunk volunteer firefighter
    Mornington, Vic
    vy ss II M6
    ahd this happen on my old vp calais, and spoke to my neighbour. he said the o2 sensors were up **** creek, so i changed it, and it went alright after it.
    If ya change them, and it keeps happening, then ive got no idea.
  3. GTP 85
    GTP 85 291 hp @ the wheels
    Murray Bridge S.A
    MY04 WRX, VS SSenator & VS V6 track weapon
    seen so many ecotec VS cars have the same problem, and both my VS's. your error codes will read 'a/f variation between L and R banks' or something similar. pull the 02 sensors out and you will notice that one i charcoaled, sure sign of the above problem.
    my remedy was to rewire a better earth for each of the oxygen sensors, as somewhere along the line between the ecu and the sensors the earth breaks down. find the right and left 02 earth wires at the ecu and reattach to a strong earth point. make sure you find the correct wires too (a gregory's manual helps)
    id at least try this before buying new sensors, as 02 sensors arent cheap!
