Not_An_Abba_Fan
Exhaust Guru
- Aug 18, 2006
- 14,639
- 1,364
- 113
- Location
- Bunbury, WA
- Strange Rover
Same post in the correct section.
Does anyone have any knowledge of how the Black Widow BW-10000 is wired? I am removing one from the missus' burnout car as it is very inconvenient to keep hitting the button every time to start it.
I have disconnected most wires and rejoined the ignition wire so I have ignition and the car turns over, but it doesn't start. From what I have read, it has a fuel pump interrupt wire, but I haven't found it yet. There is one black wire heading to the rear of the car which I have cut, but the fuel pump still makes noise. When the key was turned on with the unit still connected, the pump made a noise, but changed when the button was pressed. I'm leaning towards the fuel pump wire being the culprit, but I just need to find it. For information, it is a VC with a VT 5.0L and Haltec ECU.
AFAIK, the loom with coloured wires are the central locking wires, and all the black ones are associated with the alarm and immobilisor. If anyone has a wiring diagram or installation instructions, it would be muchly appreciated.
