Bleeding brakes (just double checking)
HRVATSKI_VOJNIK
a.k.a KRIS
Deer Park, Melbourne
VS Commodore V6
k, well tomorrow I'm gonna replace the brake pads on my VS
I've looked thought my cars workshop manual, read how-tos and watched a few videos (youtube, expertvilige)
i know what i gotta do just wanna double check with you fellas
After i replace the pads and put the calipers back, (i'll do some gentle pumps just to get the pads bedded abit) then I'll start the bleeding
so i'll get the right sized spanner and place it on the bleeder, then put a tube which is lightly coated in brake fluid, have it atleast 2 inches of the tube above the bleeder, and the end in a bottle.
I'll get the assistant to gently press the brake pedal to half way, open bleeder, let some of the old fluid out, close bleeder and tell the assistant to let the brake pedal go. then repeat this a few times until there is a nice flow of clean fluid coming out of the bleeder. then repeat with the other calipers
oh yeah, and make sure that the fluid level is around the max mark on the reservoir before bleeding & after bleeding:p
then the proper bedding instructions to complete the lot:yeah:
i hope i got it right, anything I'm missing?
thanks:thumbsup:
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
You will be pumping old fluid from your master cylinder unless you first syringe out all the old fluid from the master cylinder...also wipe the crap up from the bottom of the MC with paper toweling - then fill up with new fluid. Bleed till the new fluid comes out of the tube - this way you are filling the caliper with new fluid which is not contaminated with water which lowers its boiling point.
Bleed the rear first, the pass side and lastly drivers side. Clean the bleeder screw and use a ring spanner not an open ender. Be careful not to push the pedal past where you normally push to. (not the end of the world if you do)
Apart from that it looks like you've done your homework. Have fun and Good Luck.
HRVATSKI_VOJNIK
a.k.a KRIS
VS Commodore V6
won't that let air in?, I'm gonna leave abit of the old fluid at the bottom/base of the reservoir, or will that contaminate the new fluid?
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
It won't let air in unless you push the pedal before you fill it with new fluid - the outlet is at the very bottom of the MC and you'll notice tiny pieces of crud and mud at the very bottom which you should remove. Good Luck.
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
just pour new fluid ontop of old fluid. Sure it will contaminate a bit with the old fluid, but what are you gonna do, just keep pumping the pedal till clean stuff comes out on the first one and then the other wont even take half that long as the new fluid will already be in the lines then
lil_mickey
LOUD AND PROUD
34
Geelong; Victoria
VH 253 :-)
sounds like you have all the info u need... just remember to close the bleeder before the assistant lets the pedal up. otherwise you will suck air strait back in the line..
Chirpstr
A new project attack
34
VR Berlina M5, VP M5
Wont matter closing the bleeder before you let the pedal up. If the hose is in fluid there is no way of air getting in. Someone please correct me if I'm wrong.
VrWagz1
wollongong
correct wavez, thats the idea of having a hose so you can bleed them yourself without sucking air back in when you get off the pedal.
Dayvo
Because i can
65
South East,Victoria
VE SV6 Series 2
Thats how i done mine the other day .I used a bleeder hose with a one way valve in it .
