Bleeding L67 coolant system
Tha Tyrant
37
Qld
Vx series 2 Calais
Can U show me how urz was set up plz as I can't fit a screwdriver in between the solenoid n intake elbow
Utel67
Tasmania
Vs s3 ute
Loosen the two 10mm bolts and tilt the bypass valve actuator forward a bit.
Fu Manchu
WA.
Slug powered VZ, a VE Calais & your mum.
Easiest way is to vacuum fill if you have a compressor. It’s how it’s done on assembly and it takes minutes.
Otherwise check my thread on bleeding the VZ and VE V6 in the How To forum. It’s the same procedure I’ve used since the mid 90’s and it’s always performed better than air bleed screws etc. Was taught to me by a Holden technician.
Same method is now seen on all sorts of cars and you can buy proper bleed buckets.
Hope it helps. It will get most of the fine bubbles out.
I say all this assuming the water to air intercooler is connected to the rest of the system.
https://forums.justcommodores.com.a...c-cooling-system-repairs.279976/#post-3063798
lowandslow
NSW
V2 III Monaro
If it was a water to air plate, it would have a separate res for the intercooler fluid.
