bleeding power steering
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by trickyvr, Feb 21, 2007.
  1. trickyvr
    trickyvr New Member
    vr s pack
    hey i have to replace the p/s pump and was wondering how you bleed the air out of the system and help would be much appreciated
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Get the wheels off the ground, turn slowly from left to right keeping an eye on the fluid level. When the pump stops making a noise it is bled. This can take a while, mine took about 25 times.
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    If you're only replacing the pump and are careful that you don't let the hoses drop when you remove the pump and fill the pump reservoir and let it flood the pump you should not need to bleed the system as there will be no air in it.
    At least thats the theory. (same as bench priming a master cylinder to avoid bleeding brakes).
  4. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    There will still be a small amount of air in the system. It creates an airlock that you have to work right through the whole system. I did all that you mentioned hako but it still whined until the air was out, and it took about 100m of driving for the steering to come back too.
  5. JcB
    JcB New Member
    Pukekohe - New Zealand
    VS Calais Series II
    Not_An_Abba_Fan
    Having power steer problems myself. When you jack up the front of the car do you turn the wheels with the car running or off? Silly question but i need to know. Thanks. I think i have an O-Ring problem.
  6. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    Engine off, according to gregory's. You just turn slowly lock to lock a number of times and keep topping the fluid up as necessary... Thats how I did it when I replaced my pump.
  7. sim_vs
    sim_vs can't work out avatars :(
    VS3 Statesman
    yeh its alot easier to bled it if u just turn the wheels manually with the engine off. generally 10 times lock to lock either side will do it i've found.
  8. JcB
    JcB New Member
    VS Calais Series II
    Thanks for the info guys.
  9. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Then do it a couple of times with the engine running to get the fluid moving through the whole system.
