Blending paint
Snotty
34
the shire!
VR Berlina auto s2
g'day,
need a bit of help. Im going to be painting my front bar, Its going to be solid blue, and im going to do the insert with a metal flake (the type you mix into the clear).
Now my problem is im not clear coating (cause its a solid colour) and i dont know how to blend the flake with the solid, There isnt a very clear edge.
otherwise there would be a lip between the two.
hope this makes some sense.
cheers
Snotty
34
the shire!
VR Berlina auto s2
but wouldnt that creat a lip where the tape is pealed off?
hakhawk
smooth moderator
Staff member
35
bit of light sanding after its dry and another coat of clear to seal it
ducatis
Lennox Head
VS UTE
unless you want to free hand it. as hakhawk said use the finest grit you can find give it a sand maybe. im a cabinet maker not a panel beater sorry
Snotty
34
the shire!
VR Berlina auto s2
free handing? I dont think i explained it properly.the blue line is there to show that i was going to do the inside metallic.
Snotty
34
the shire!
VR Berlina auto s2
i guess my main problem is will their be a difference where the blue has been clear coated and where is hasnt?
Holden2gether
The short,chunky fella
Christchurch,New Zealand
VY S
Just spray the whole bar with clear once you've done the flake,just because the blue is a solid colour doesn't mean you cant clear coat it.You'll end up with a far better looking job too,the clear gives the solid colour more depth and IMO gives a far better gloss & shine:thumbsup:
I respray musical instruments and have tried polishing the plain solid colours (when I first started out) and they just didn't have the depth and gloss that a clear coated instrument has.Well worth the extra effort.
