bloody VS headrests
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Brycestro, May 20, 2006.
  1. Brycestro
    Brycestro New Member
    VS Acclaim S2
    Hi everyone, i've just bought some seat covers off of a member on here (wanted7) and i need to remove the headrest to get em on. Now i've read another few posts on it, some mentioning some sort of 'clip' or something that needs to be released... i've tried picking around in there with a small screwdriver but can't find any 'clip' as such.
    I also read in a post that the older model commodores had an easier release mechanism and that with the relatively newer models (VS etc) the 'clip' was placed in some plastic thing AND THEN had the seat material placed over the top making it extra hard to get to. I don't really want to have to do what the other post suggested: strip back the seat material right up to the headrest to find this infamous 'clip' and undo it, so si there anyone else who's removed a headrest in a VS before that can shed some light on this problem?
    Thanks alot everyone, cheers, Bryce.
  2. Brycestro
    VS Acclaim S2
    come on... surely someone out there has to know or has had the same problem.
  3. 08_adaml
    08_adaml New Member
    VY SII Spac Manual
    I couldnt find the clip as well, pretty dodgy! lol
  4. Brycestro
    VS Acclaim S2
    sure is, i'd go chainsaw massacre style on it but i want my headrests back on once the seat covers are on. Anyone else have any ideas! please! if anyone has seen how dodgy half a pair of front seat covers on looks you'll feel for me here at the moment :p.
  5. sixshooter
    sixshooter New Member
    2x VS
    All I can suggest is to try sticking a safety pin down alongside the headrest rod on the side with the notches to see it you can push back the catches while you or someone else pulls upward on the headrest.
  6. Brycestro
    VS Acclaim S2
    ah ok cool. i'll give that a go later on. anyone else have any other ideas at all? anyone have a picture of the elusive 'clip'?
  7. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Maybe a feeler guage blade down the rod? ....
  8. hako
    Toowoomba SE QLD
    VS11 BT1 V6
  9. Brycestro
    VS Acclaim S2
    Hey hako mate, thanks for the reply. What exactly is a feeler gauge blade? And yeah... i've read that post, i've been through all the posts on headrests and still haven't found anything that's shed much light on it. Surely there has to be a way to get them off without taking off the damn seat covering material.
    Cheers.
  10. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    A feeler guage is a strip of spring steel about 100mm by 16mm (4" X 1/2"). They come in varying thicknesses and come in a set of maybe 10 or 20...cost but a few dollars. Used for setting ignition points or valve clearances etc.
    How about about of hacksaw blade with the teeth ground off.
  11. Brycestro
    VS Acclaim S2
    hhhmmm is anyone able to describe what this clip is like? i can sort of see the white plastic bit, is the clip actually on the inside of this plastic itself or what? i tried sticking a safety pin down inside the plastic bit but i couldn't even fit that between the plastic ring and the head rest legs, so not looking hopeful on fitting a hacksaw blade down there. Cheers.
  12. Slow VR
    Slow VR Another White Crummodore
    Cairns, Nth Qld
    VR Series II
    Geez, glad its a piece of piss to get VR headrests off.
  13. Brycestro
    VS Acclaim S2
    yeah ya lucky bugger. anyone else managed to get these damn VS headrests out?
  14. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    Maybe someone needs to find a burnt out VS or a seat frame without the fabric to find out how they are retained in the seat.
  15. Brycestro
    VS Acclaim S2
    yeah, if only that someone could come help out here about now that'd be brilliant :). Cheers everyone for your help so far anyway though. Ideas people... ideas...???
  16. Brycestro
    VS Acclaim S2
    ok, i'm now offering my appreciation and a virtual pat on the back to anyone who can shed some light on this :p i.e. - *bump*
  17. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    VE OMEGA 3.6L Dual Fuel
    OK..Here it is..:wave:
  18. Brycestro
    VS Acclaim S2
    dude, your a damn legend. I'll give that a go tomorrow and see how i go. Might need a little help with some of the terminologies there, but i'll see how i go anyway.
    Oh yeah *hands over virtual pat on the back* well done :).
  19. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    From the thumbnails courtesy VT_Acclm, the headrest posts still look like they should just pull straight up....When mine is fully up I count 4 detents as per the thumbnail and hidden under the trim is a tapered section of the rod??....maybe the clip goes thru a hole in the post. Bit of a bugger having to pull the seats apart.
  20. Brycestro
    VS Acclaim S2
    hhhmmm i had another look today but still can't see much at all down in there because the seat covering is hindering the view. Don't really want to have to go to the extent of taking off the seat covering, it may be a case of giving my seat covers the chop and just letting them slip right over the headrest and on, then maybe a couple of stitches or velcro to hold it together. HHmmm tis dissapointing :(.
    By the way, VT_Acclm, do you have any pics of the so called "hog" somethign or others that guide refers to? Cheers, Bryce.
