Blower will not turn off
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Clubby Lover, Jul 26, 2012.
  1. Clubby Lover
    Clubby Lover New Member
    Newcastle
    VS Clubsport
    My blower fan in my statesman (96) won't turn off. I've taken out the fuse to stop it and I've tried replacing the fan amplifier but it still hasn't fixed the problem. Ideas anyone?
  2. m1lky
    m1lky New Member
    Auckland
    VY SS
    Using a multimeter you should be able to diagnose at the fan resistor whether it's the resistor or the control unit.
    Sounds like the resistor to me though. Not sure where they're located in the statesman though sorry.
  3. monkeys437
    monkeys437 New Member
    Mornington, Melb
    VS Stato l67
    Doesn't the fan default to ON when the coolant temp sensor shits itself? I think I might have read that in my service manual once
  4. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    Depends on which fan we are talking about. If its the one for the aircon/heater it may be the resistor. If its the thermo fan under the bonnet i would start by swapping relays. Then mobe onto sensors
  5. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    You may have a faulty blower relay. It's located in the relay housing assembly under the bonnet. If you swap it with (say) the horn relay you should be able to tell whether or not the relay is the problem.
  6. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    When I saw 'Blower will not turn off' - I thought you were wanting a Mad Max style blower.
