Blown torana
78_torana
l67 torana
Yeah I always knew TCI did one I was just after alternatives but seems like there is none. Basically it will turn the auto into a full manual with the shift pattern reversed.
P
R
N
Because it's full manual if it was the standard shift pattern parking n going from R to 1st would be painful with the pro ratchet shifter
78_torana
l67 torana
So with the rev pattern I only need 2 clicks to go from 1st to rev n vice versa as opposed to 5
78_torana
l67 torana
box was done just in time for nostalgia drags. Awesome day, some really fast cars there made mine look so tame. Met fatslr off the forum he's got a very tidy hatch. First run got a 14.3@104 sonething wasn't right, got back to stafin n found no5 lead had caught the chassis rail n popped offend plug, problem sorted next run got a PB of 12.27@111. Followed by 12.3 n a 12.6 trying different launches.
Couldn't get any better times into the night. One I didn't stall up hard enough and the other got no traction as my street Tyres had started to clay up.
All in all pretty stoked, first elimination dialled in 12.27 other guy dialed 12.99 had him at the end n backed off way early and did 12.279@105! Would have been interesting if I didnt have to. A mate got some videos, hopefully he gets them up. Got eliminated next run, not enuf stall n poor reaction time.
UC Torana - Nostalgia Drags - 14.04.2012.wmv - YouTube
78_torana
l67 torana
Bit of an update
Something else joins the parts collection in the shed :) link ecu is also on the way. Plan is to just retune with link, put tot cooler kit on, feed it some gas n see wat I can get out of it, should go very low 11, hopefully the bottom end holds on, also stock heads may hamper it a bit
78_torana
l67 torana
update time, been in europe 4 weeks but getting a bit more done now im back and not doing fifo work anymore/
-12 fittings welded on, spent a bit of time polishing these up nice. They had some deep scratches and were in a flat #2 finish when i bought them. Now full #8 mirror finish.
more port work on the blower, ive removed the "bridge" this normally seals air off to the factory intake manifolds square intake, Now that im going to be raunning a w2a core under it i need as much surface area as possible so ive opened it all up and ported the intake manifold to match.
cooler plate pulled down, n cleaned up, now resealed.
Since im going to be running ls1 coilpacks i wont be needing these bolt bosses anymore. Plenty hours ahead!
basic shaping
only had 150grit sandpaper, not course enough to get my lines set n straight. Yes im a fussy prick :)
On another note i pulled wiring loom out and also discovered that the e85 in my lines has eaten thru the permaseal on the fittings in my fuel rails....
you can see the green coming thru, the e85 has been in there since january, im going to assume my injectors are gummed up aswell, i might also cut down a piece of rubber hose inline and have a look inside. Lucky there is very minimal rubber hose maybe 180mm total on supply side
78_torana
l67 torana
had a bit of a fail haha. The -12 fitting on my passenger side rocker cover fouled on the intake pipe. Now because i had the carbon ubend drilled to sit high because i wasnt using a cooler plate the angle from the tb to where my pod is is wrong. So i got a piece of 4" stainless mandrel bend scrap i had laying around and set about making it all work and of course look good 8.)
borrowed a 4" cutting block from work, these work mint, i wanted a perfect fit as i wanted to purge the pipe so inside will be smooth and also look like it been welded on the inside.
i dont want to bore every1 but if u want i can give a bit of a rundown on how i got to this finish, i took a few pics along the way, might help others at home who want to do/learn polishing
