BMW rims fit commodore?
PlenumBiscuit
VY Commodore
am hearing beamer rims fit commodore?
vc commodore
Like the Leyland Brothers
VC, VH and VY
Yes they bolt on....As for the offset side of things, I am unsure.....
A few years back, I put a standard 15" commodore steel wheel on a BMW, to get the owner out of trouble....He put a steel rod through his tyre and damaged the rim as a result....The car didn't come with a spare so this was the next option, which worked
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
BMW have the same 5 x 120 stud pattern, but I'm not 100% if all BMW models do though
Wheel offsets is where you are likely to run into some trouble
Try having a crack with the search function....I do remember reading a thread about this on here a while ago
Surfwagon
Sydney/NSW
AMG Mercedes C63 Wagon
I had BMW BBS rims on my senator in 18x8+9" and the offsets were perfect.
As others have said its offsets that you need to check before buying .
Also a good idea to get proper hubcentric rings to make sure the wheels are centered on the hub.
